Mechanics
F150 CLUTCH
1997 Ford F-150
Transmission problem
1997 Ford F150 V8 Two Wheel Drive Manual
My clutch pedal stuck to the floor, I realized the pushrod broke. How do I replace it?
Christian12387
January 2, 2009.
CLUTCH PEDAL PIVOT SHAFT LEVER
Removal
Disconnect clutch master cylinder push rod from clutch and brake pedal pivot shaft lever pin. Use a small screwdriver or putty knife to wedge between lever and snap-in bushing. Remove retaining nut. Pry lever from clutch and brake pedal pivot shaft.
Installation
Snap new lever to clutch master cylinder push rod bushing. Install lever onto clutch and brake pedal pivot shaft. Tighten clutch master cylinder and pedal bracket. Install retaining nut finger-tight. Ensure clutch pedal position is against up stop. Tighten retaining nut to proper specification, allowing knurled teeth on clutch and brake pedal pivot shaft to cut matching teeth in lever for correct positioning.
Dave H
Jan 2, 2009.
AD
