Mechanics
F150 EOD NOT WORKING
1996 Ford F-150
Transmission problem
1996 Ford F150 V8 Two Wheel Drive Automatic 160000 miles
hello, my eod (electronic over drive) light is flashing and the speedometer/odometer are not working. What would be the cause of this problem? Thanks in advance for any help.
Gmm
March 5, 2008.
Tranny need to have the codes read most likely it slipping
scan the TCM for codes
AD
BMRFIXIT
Mar 5, 2008.
Check the speed sensor. It is either located on the tailshaft of the trans or on top of the rear differential housing. If the computer can't sense speed, it won't feed info to the speedo/odometer and it also won't know when to shift. O/D light will probably flash a P0500 code, but check to be sure.
Flexy5
Mar 5, 2008.
AD
