Mechanics
F150 TURNS OVER BUT WONT START
1995 Ford F-150
Engine Performance problem
1995 Ford F150 V8 Four Wheel Drive Automatic
My pickup just started to act a little funny in the sense it idles hard at various times mostly on a cold start up. But recently it will turn over and not start after it has been started before. It sometimes dies when shes cold and I try to drive it. I changed the fuel regulator pump with no luck. Stumped, could it be the air mass flow meter? Just not sure
351fordman
January 6, 2010.
Check the fuel pressure with a fuel pressure gauge if its within specs if so--clean out the idle air control valve and test the throttle position sensor and MAF sensor
Rasmataz
Jan 6, 2010.
