Mechanics
F150 REPLACEMENT OF GAS TANK
1995 Ford F-150
Engine Mechanical problem
1995 Ford F150 6 cyl Two Wheel Drive Automatic 75000 miles
I have a Ford F150 with a leaky rear fuel tank. Can I just remove the rear tank and plug the lines or will this cause a problem? Is there any information on how to properly remove/replace a fuel tank on a Ford F150?
Projectguy
April 19, 2008.
You can leave the tank on there and just use the front tank, dont have to drop it and plug it, you could if you wanted.
To replace a tank just disconnect all hses and wires and cut the straps, and your done.
Blackop555
Apr 20, 2008.
AD
