1995 Ford F-150 rear end!
JLINN91
  • 1995 FORD F-150
  • V8
  • 180,000 MILES
I have just recently replaced the rear end in my 95 f150 but the rear end I used came out of an 88f150.Q. There is some kind of wiring deal that hooked up on my old rear end but there is no where to put it on the 88yr. Model rear end. You can see it has wires and on the end it looks like a metal ear off of a u-joint. Is this what changes my truck into overdrive.
Friday, September 11th, 2009 AT 7:10 PM
  • 108,179 POSTS
They change things so often, it is hard to tell. We always recommend staying with direct replacement parts for this reason. To answer your question, no, that has nothing to do with overdrive.
Wednesday, September 16th, 2009 AT 8:15 AM
HAIRBALL989
In the newer model it has a shift sensor in the rearend, the older it is on tranny
Saturday, September 19th, 2009 AT 3:04 PM
  • 108,179 POSTS
What hairball989 (great name by the way!) Said is correct.
Sunday, September 20th, 2009 AT 7:59 PM
JLINN91
  • 8 POSTS
Yea that makes a lot of sense I just got my vaccum lines and wiring replaced and 3 injector connectors. Damn rats. Reason it makes sense is because yesterday when I drove it it doesnt wanna change into gear right it overrevs and when it finally does the whole truck snatches.I thougt this was something to do with overdrive cause my overdrive button flashes now. So is there any suggestion to what I can do about gettin this sensor back right so my truck will change into gear right.
Friday, September 25th, 2009 AT 11:44 AM
Related General Content
