Mechanics
F150 ERROR CODE 122
1995 Ford F-150
Engine Performance problem
1995 Ford F150 V8 Two Wheel Drive Automatic 240000 miles
I began to have an intermittent problem of lack of throttle response, usually after driving for 30 or 40 minutes. Engine light would come on, but it would kick back in and run ok for a bit, then repeat. I replaced the ignition control module, engine coolant sensor, and TPS. The error code I get is 122. Do I need to run new wires from the tps to the ecu? If so, do all 3 go to the ecu? This is new terratory for me.
Thanks in advance for any help.
Bmwhendrix
October 25, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
