Mechanics
F150 CLUTCH MASTER CYLINDER
1995 Ford F-150
Transmission problem
1995 Ford F150 6 cyl Two Wheel Drive Manual
i have a 95 ford f150 I have replaced the clutch master cylinder three times the problem is that the rod that hooks to the clutch pedel keeps poping off ive replaced the clip but it dosent seem to help I cant see anything bent or out of alinment any ideas where to start to resolve this problem
Ford1995
February 28, 2009.
Hi there,
take off the clip & drop off the push rod, feel for any sideways movement in the pedal, the pedal pivot bush & pin may be worn, check this next.
Mark (mhpautos)
Mhpautos
Feb 28, 2009.
AD
