2CarPros - Car Questions & Answers
1995 Ford F-150 Repair Question
Topics covered: Distributor, Engine, Gas.
Asked on April 13, 2010
F150
Engine Mechanical problem
1995 Ford F150 6 cyl Two Wheel Drive Automatic 150000 miles
hello, I was driving and it just stalled and it did not want to start up. I changed the ignition coil, the whole distributor, the battery, i checked the gas lines. checked the spark plugs, checked to see ir there is a spark, it is weak but there is ine, after i changed the distributor. i wonder if i moved the timing. the engine cranks but it does not start. i checked if there is gasoline in the tank and there is.
I dont know what else it might be .
HELP.
THANK YOU ,
JOSE SANCHEZ
Avatar Asked by refugio
No Answer Yet
