1995 Ford F-150 Repair Question
Topics covered: Tool, Engine, Engine performance.
Asked on March 9, 2009
1995 Ford F150
Engine Performance problem
1995 Ford F150 V8 Two Wheel Drive Manual
how do you go about removing the big line that i think go to the motor for fule on the tank. i got the othere off with the special disconnect tool. the line is bigger then the 3/8 one. could i cut the one thats in the pump since its a in the tank pump and then jsut trying to get it out that way. what dose a new pump come with the lines for the return and the motor?
Answer
Replied on March 9, 2009
I woud get the right tool. You should have a clip like this in the fuel line.
Other wise you have this type which are even easier to get off.
