Mechanics
F150 HEAT DONT WORK
1994 Ford F-150
Heater problem
1994 Ford F150 V8 Four Wheel Drive Automatic
i just changed my heater core, the heater core is producing heat the deforst blower works but the air that comes out is cold can u help thank you
Rich77
December 11, 2008.
Did you replace the thermostat if not do so and try if it works-If not could be a heater control valve if it has one, air mix/blend /mode door problems also an actuators and vacuum-HVAC control module.
Rasmataz
Dec 12, 2008.
AD
