Mechanics
F150 WILL NOT IDLE
1990 Ford F-150
Engine Mechanical problem
1990 Ford F150 V8 Four Wheel Drive Manual
After driving the truck for about 30 mins. The truck will not idle when I come to a stop. If I rev up the motor then it will idle. The mechanic fixed a couple of vacuum lines and the line to the smog pump and said that the problem was fixed.
JNavitsky
May 21, 2008.
Have the idle air control motor/valve and throttle position sensor and EGR valve checked and tested.
Rasmataz
May 22, 2008.
