Mechanics
F150 MOTOR MISSING
1989 Ford F-150
Engine Performance problem
1989 Ford F150 6 cyl Four Wheel Drive Manual 160km miles
motor runs good when cold when warmed up it starts to miss and shake
Camsmith
July 14, 2010.
Engine running rough or misfiring can be caused by the following: 1. Defective spark plug
2. Inadequate spark/coil, defective spark plug wire.
3. Lack of compression
4. False air leakage.
5. Faulty fuel injectors.
6. Insufficient fuel pressure.
7. Contaminated fuel.
8. EGR valve that is leaking.
9. Oxygen sensors.
10. Throttle position sensor.
11. Idle air control valve.
Rasmataz
Jul 14, 2010.
AD
