2CarPros - Car Questions & Answers
1988 Ford F-150 Repair Question
Topics covered: Starter, Clutch, Fusible link.
Asked on January 2, 2008
1988 Ford F150 Will Not Start
Truck stalls without warning and starter circuit is dead, headlights work, inside warning bell works, radio will not work. This has been going on for two years and I have not been able to find the problem. It will eventually start after sitting for some length of time, sometimes days, sometimes weeks, might run for a day and might run for 6 months, cold or hot engine doesn't seem to make a difference. I have replaced ignition switch, starter relay, battery ground cable and ignition control module to not avail, any advice would be greatly appreciated.
Avatar Asked by heelpin
Answer
Replied on January 2, 2008
Thank you for your donation
When the truck won't crank, you will have to back check from the starter,
Main Power at starter,
Power at Solenoid whit key on crank.
Starter relay power from fusible link & power from key at crank.
Clutch switch continuity when operating.
Power to clutch switch
The fusible link powers up the ignition switch and the main feed to the starter relay. There is nothing else in the diagram as far as the starting circuit is concerned. carefully check each component when it won't start and you should find the cause. Do not disregard faulty starter or any component replaced and check continuity of wires as there may be a broken wire that is making a partial connection and then becoming open circuit.
Mark (mhpautos)
Tiny Answered by mhpautos (expert)
26,882 answers provided
