2CarPros - Car Questions & Answers
1983 Ford F-150 Repair Question
Topics covered: Rim, Spark, Distributor.
Asked on February 26, 2009
1983 Ford F150 backfire
Engine Performance problem
1983 Ford F150 6 cyl Four Wheel Drive Manual
I have suddenly had a backfiring problem, and it is stumping me, as it seems to only happen when I am turning. The problem is twice as bad when turning left, but have noticed the occasional miss when driving straight
Avatar Asked by nriemer1
Answer
Replied on February 26, 2009
When the last time you had it tuned-up? Check the sparkplug wires if its leaking and also the distributor cap.A/F mixture could be too lean or rich, Air injection diverter valve and the lis tgoes on.
Tiny Answered by rasmataz
68 questions asked
just started suddenly, but what would make it happen primarily when turning?
Tiny Response from nriemer1
4 questions asked
Honestly I've never heard of such problem-I will check the sparkplug wires they move around when not secured properly and could be leaking into one another
68 questions asked
Replied on February 28, 2009
I figured this one out last night, I had a partial break in the coil power wire, and the retainer for the wire had broken, letting it swing back and forth while turning. this momentarily broke the connection, letting gas build up in the cylendars and exhaust until it fired again, then BOOM!!! Fixed the wire, and replaced the coil connections also, seems to run fine now!!
THANKS FOR THE HELP!!!
4 questions asked
