Transmission
FORD EXPLORER
RIVETS MP
Yes, i have a 93 Ford Explorer, and wheni start the engine, i cant seem to get it into gear. I just had the slave receptical replaced. and the fluid drained and replaced. what else could the problem be?
Feb 22, 2006 at 6:32 AM
LOVESCARS
  • CAR REPAIR CONTRIBUTOR
  • 359 POSTS
if you meant the slave cylinder have the system bleed again these are a pisser to bleed. i assume this is a manual trans
Feb 22, 2006 at 8:08 PM
