2CarPros - Car Questions & Answers
Ford Explorer Repair Question
Topics covered: Wheel, Wheel bearing, Brakes.
Asked on August 3, 2006
Putting on brakes
I have a 1999 Ford Explorer XLS 4 door 2 wheel drive with 73,000 miles and a v6 4.0 ohc motor. I had to replace the right rotor with a new one, and i replaced both front brake pads, which work fine. But when i start to take off or when i tested them and got up some speed my truck started to vibrate. any help with this problem is appreciated. the truck never vibrated before changing the brakes.
Avatar Asked by georgia_bunny69
Answer
Replied on August 5, 2006
My guess is that the side that you did replace is either warped or not setting on the hub flush. Somtimes you get a new warped rotor. Rare, but possible. Should replace both rotors.
Tiny Answered by Service Writer (expert)
9,955 answers provided
Replied on August 6, 2006
thanks but i found out the problem once i replaced my right rotor because it was so bad i had to also replace the inner and outer wheel bearings. but thanks for the help
Tiny Response from georgia_bunny69
1 question asked
Replied on August 7, 2006
There is somthing wrong here. That truck doesn't have an inner and outer wheel bearing. It has a wheel bearing that is part of the hub assy.
Here is a lnk to see it:
http://www.1aauto.com/1A/4WDrive/Ford/Explorer/1ASHF00003/422658&ovchn=OTHER&ovcpn=GoogleBase&ovcrn=&ovtac=CMP
Whoever did the work should show you the old ones.
This is what you said: "the truck never vibrated before changing the brakes." Therefore the wheel bearings should have nothing to do with your vibration. I think somthing wasn't done right on the brake job the first time and someone's screw up was covered up afterwards.
