Mechanics
IDLE
Ford Explorer
I have a 2002 Ford Explorer Sport Trac 2wd 4.0L with 75,000 miles. Within the last 5 days my engine light has come on, and it will not idle properly. Once it goes below 1000 rpms it cannot maintain an idle. The rpms will fluctuate between 800, 1000, 500, and lower until it stalls. If I keep the engine at over 1000rpms while stopped it will not stall. At higher speeds and rpms there does not seem to be a problem. The only other thing I have noticed, is that it seems a little sluggish when you hit the gas. Do you know what might be wrong?
Da249er
April 23, 2007.
If you could post the codes it would help, but idle problems are usually The Idle air controller, or the Mass air flow sensor.
Merlin2021
Apr 23, 2007.
AD
