Mechanics
SENDING UNIT LOCATION
Ford Explorer
Where is the oil sending unit on a 2001 Ford Explorer with the v6 OHC?
I know it needs replacing, but can't locate it.
Thanks in advance
Stuknbama
January 4, 2006.
ANYONE out there?
AD
Stuknbama
Jan 11, 2006.
Does anyone have any idea on where this is located?
Stuknbama
Jan 28, 2006.
Usually on the block semi close to where the oil filter is located it will look partially like a spark plug with a wire on top. If may also be leaking motor oil if no good.
Lovescars
Jan 28, 2006.
AD
