2CarPros - Car Questions & Answers
2005 Ford Explorer Repair Question
Topics covered: Sensor, Wheel, Abs.
Asked on December 4, 2007
Advance trac light
Electrical problem
2005 Ford Explorer V6 Four Wheel Drive Automatic 23000 miles
My 2005 Explorer was in an accident and now the little Advance Trac symbol is lit up on the guages and in the information center, it says to "check advance trac". What would be causing this problem. Is there a sensor I need to replace?
Avatar Asked by Billroy24
Answer
Replied on December 5, 2007
Could very well be. To be sure the system will need to be scanned for codes.If a wheel sensor or some wiring was damaged, then the traction control/ABS system will turn on the light letting you know there is a problem
Tiny Answered by Jack42
21 questions asked
