Mechanics
FORD EXPLORER COOLANT PROBLEM
2005 Ford Explorer
Engine Cooling problem
2005 Ford Explorer 6 cyl Four Wheel Drive Automatic
The lower radiator hose came off and all the coolant leaked out. I filled the coolant back up after reconnecting the hose and the vehicle overheats and makes a bubbling sound. How do I fix that?
AD
Jcsummit
January 2, 2010.
If you hear boiling coolant, the engine is running way too hot. First, have you tried replacing the thermostat? How long does it take for the temp gauge to go to the high / hot side> Let me know.
AD
