1995 Acura RL the service engine code light came on
1995 ACURA RL
150,000 MILES • 6 CYL • 2WD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
1995 Acura RL mileage: 150,000. I had the transmission rebuilt by a reputable dealer. After one week the service engine code light came on and the transmission jerked very roughly when put into gear. They diagnosed that a circuit that went through the ignition switch was the culprit. They changed out the switch. That solution lasted about 3 weeks before the code came back and the transmission bucked. They took the car, dove it for about two hundred miles but the problem did not reoccur for them. But it happened again yesterday. They removed the code, the same code that told them the ignition switch might be the problem, and the car runs fine. This problem occurs only when starting the car, never when in operation. Any suggestions?
Oct 9, 2010 at 1:26 AM
2CP-ARCHIVES
  • 4,540 POSTS
Check for loose or missing ground wires to the engine/transmission assembly. Also, look for bad connections in the main power wires and in the main power distribution panel.
Oct 9, 2010 at 1:30 AM
