Mechanics
CHECKING AUTOMATIC FLUID LEVEL
2002 Ford Explorer
2002 Ford Explorer V8 Two Wheel Drive Automatic 38000 miles
MY 2002 EXPLORER IS MAKING SOUNDS LIKE IT IS LOW ON TRANS FLUID. IT REVS WHEN YOU DEPRESS THE ACELERATOR PEDAL ENOUGH TO MOVE OUT QUICKLY. THEN IT DOES NOT SHIFT PROPERLY. IT SEEMS TO SLIP WHEN SHIFTING. ON THE OTHER HAND IF I START OUT SLOWLY IT WORKS JUST FINE. I JUST HAD A SHOP DRAIN AND FLUSH THE TRANS ABOUT 3MONTHS AGO. PLEASE EXPLAIN HOW TO CHECK THIE FLUID LEVEL AND ADD FLUID IF NECESSARY. THANKS
LARRR1961
August 9, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
