Mechanics
4 WHEEL DRIVE CONTROL MODULE
2002 Ford Explorer
Engine Performance problem
2002 Ford Explorer 6 cyl Four Wheel Drive Automatic 100000 miles
every time I start my truck and I push buttion that said " 4 wheel drive high" as I see on dash broad that yellow light said " 4 wheel drive high" on then I start drive about over 30 m.P.H. Then the dash broad " 4 wheel drive high" went off on me so I hit buttion " 4 weehl drive high" then yellow light come on but if I go over 30 m.P.H. Then it stud down the 4 wheel drive. As I have snap on computer obd-II and I got the 3 differant codes that said B1134 faulty control module. And other one siad P1812 4WD mode Select switch circurt faulty. And other codes said B1322 LF door adjar Circuit short ground. I want to repair my self which it will saves me alot money. It is possble that 4 wheel drive module is no good? And what about the control switch? Let me know
J.j.shabro
June 3, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
AD
