windshield wipers not working
2001 FORD EXPLORER
CAJUNFOWLER87
Six cylinder two wheel drive automatic
my windshield wipers went out yesterday and i have replaced the wiper fuse and the relay fuse and they still will not work. what may the problem?
Jan 30, 2010 at 1:21 PM
SCOTTY DEE
  • CAR REPAIR CONTRIBUTOR
  • 592 POSTS
Did you check CJB Fuses 8? Is your an early build 2001 or late build?
Dec 31, 2016 at 3:05 PM (Merged)
CAJUNFOWLER87
TAKETHEMONEY
Electrical problem
2001 Ford Explorer 6 cyl Two Wheel Drive Manual 121,00 miles
My windshield wipers stopped working checked fuses under hood and inside panel under dash nothing no movement at all. Rear windshield wipers work no problem front wipers does not work.
Dec 31, 2016 at 3:06 PM (Merged)
  • 110,190 POSTS
If the fuses are good, have you checked to see if there is power to the wiper motor?
JODY CONRAD
2000 Ford Explorer
We have checked the battery and it is fine but still will not start. When we try it stutters. Is it an electriical problem or a cable? We also have had troubles with the windows will not go up and down and the windshield wipers do not work.
Dec 31, 2016 at 3:08 PM (Merged)
  • 110,190 POSTS
It sounds like a battery problem. Did you load test it or do something differently? Also, have you checked to make sure the battery terminals are clean and tight? Have you checked the ground on the engine block?
