Battery draw?
2010 FORD EXPLORER
800,000 MILES
MARY MENARD
Pulled #2 fuse in passenger compartment fuse box and problem went away. what is my next step?
Aug 29, 2016 at 7:10 AM
HMAC300
  • CAR REPAIR CONTRIBUTOR
  • 48,601 POSTS
put fuse back in and check for a parasitic draw to see what fuse is connected to fuse 2 powers smart junction box which may be bad have a look at this guide to help us find the problem
https://www.2carpros.com/articles/car-battery-dead-overnight
Aug 29, 2016 at 9:49 AM
MARY MENARD
Sorry,what is the smart junction box...and where is it?
Aug 29, 2016 at 10:38 AM
HMAC300
  • 48,601 POSTS
that is the fuse box inside the car it has some electronics that run different things. see pic it powers the horn relay which is an integeral part of the smart junction box. I don't see any tsb's or recalls on this but check with a mechanic he may be able to fix it without getting a new junction box.
Aug 29, 2016 at 10:50 AM
MARY MENARD
This is the fuse box we pulled #2 out of. What is next?
Aug 29, 2016 at 11:10 AM
HMAC300
  • 48,601 POSTS
The relay for the horn is internal so it has to have the whole fuse box replaced or a mechanic will have to wire a separate relay in if there is no short in wiring keeping the draw going.
Aug 29, 2016 at 11:57 AM
CAROL 38
my battery goes drained after setting two days. I was told it has something to do with number two fuse.
Dec 21, 2020 at 10:47 AM (Merged)
Good morning.
If you remove the fuse does it still drain? This guide will help fix it
CDOVES
I have gone through 3 batteries in the past six months. As soon as the car sits for a day or two the battery is dead. Went to get a quick free alternator,starter test and they said both were fine. I finally take it to a dealership. They just called and said my starter is drawing excessive ampage and that is why I have the long crank... I didn't even know I had a long crank.... I ask if the starter would drain the battery as it sits and they said no but that my starter problem would cause it not to start... I keep trying to tell them that my issue is that something is draining my battery... If we recharge the battery the car starts no problem... Something is not adding up to me and they won't allow me to talk to the tech directly??? I really don't understand that part... anyhow will a bad starter drain the battery when the car sits idle for a couple days???
Dec 21, 2020 at 10:48 AM (Merged)
SATURNTECH9
  • 30,869 POSTS
it's possible tell the dealer you have it at you want them to check.for.excessive parasitic draw.
CDOVES
Thank you for your response. I did have them check and they said they found no drains. I guess I will just give the ok to replace the starter but I just can't fight the gut feeling that the starter is not my main problem.... It's just frustrating... Thank you again for your time
SATURNTECH9
  • 30,869 POSTS
if it still.drains.let me know.and we.will.talk more about it.
WRESTLER158
My 2006 Ford Explorer has a phantom battery drain every 3-5 days. I took my vehicle into the local Ford dealership and a local auto electric shop where they performed system and draw tests that showed no draw on the battery. They told we they would have to have it hooked up to the tester when the draw was happening in-order to catch it. Could this be something as simple as the radio not shutting down or the mercury switch on the hood light sticking and running the battery down when the car is turned off? Or would their tests catch this sort of draw? It seems kind of ridiculous that the dealership has no answer for this problem.
This can be just a weak battery that needs to be replaced but to be sure here is a guide to help us.
if okay this guide will help run down the battery drain issue.
WRESTLER158
Thank's I went over the guides and ended up replacing the battery which fixed the issue, great site btw I cant believe it is free.
FOLEY777
  • 6 POSTS
The ABS fuses when pulled touch them and they will light up the tester. Is there anyway to find where the short is? i know nothing about electronics. Also the ABS light came on and wont shut off. Lee
Good afternoon,
You check current draw, not voltage. Voltage does not drain a battery, current flow does. I attached a guide for you to follow.
TBICE3095
I have replaced my car battery, i also replaced the starter and alternator. I took out the #40 fuse and the battery light finally went off. What does that mean? Also before i put the new battery in yesterday i had to keep jumping it off and i changed the wires on the battery. Also the driver door electrical system does not work. On the dash it keeps saying door ajar and the overhead lights stay on. What could that be?
Good morning,
If you install the fuse, does all the other accessories work again?
Can you verify that fuse number? It does not show on my diagrams.
I attached a wiring diagram for you to view. Make sure you have power to the alternator with the key in the on position.
DANNY WHITE
Something is draining the power in my battery. I have checked the interior lights, headlights, cigarette lighter, glove compartment light, and under the hood but can't find the culprit. Battery and alternator are good. Any suggestions?
TBEAUWHITE
if you have a test light, you can take the negative battery cable off, attach 1 end of light to the battery and 1 end to the cable, if it lights up bright you for sure have a drain. with light attached start pulling fuses 1 at a time and see if light goes out. if it does at least you have found the circuit that is causing the problem, make sure you check and see what all is controlled by that fuse. also make sure all doors are shut and hood light bulb is out. hope this helps
HEYSCUBA
sweet,.. this is the answer to my problem,... heading out to pull fuses now,..
(I guess you can also use an amp meter,...?)
JOESWENNING
If i leave any accessory on for a couple of minutes my battery will be drained and just start clicking. Battery is a optima yellow top and it has been tested and it is fine. Also had the altenator and starter tested and they said they were fine. But it doesnt make sense bc it seems like the altenator isnt charging back up the battery. The truck starts but it usually take two cranks to start. And if i leave my headlights or doors open for a few minutes my battery goes dead.
Dec 21, 2020 at 10:49 AM (Merged)
  • 110,190 POSTS
Start by making sure the battery terminals are clean and tight. Also, the interior lights are not enough to drain a good battery in a couple minutes, so there is more to this.
Let me know about the terminals.
JOESWENNING
Battery terminals are clean and tight and brand new.
  • 110,190 POSTS
I need you to test for an electrical draw. Here is a how to. What I need you to do is check how much of a draw is present. Also, is the draw still present under the conditions that you mentioned. Finally, if the accessory is causing the draw and you shut the accessory, does the entire draw stop.
Here are the directions. Let me know what you find.
https://www.2carpros.com/first_things/why_is_my_car_battery_dead_over_night.htm
JOESWENNING
Does it have to be a test light? or can I use my meter?
MISSVAL38
Issue: Battery will not hold a charge if vehicle is off for a short period of time, unless it is fully charged. It can then be turned off for a few hours or more. Over a period of time, it drains. The first sign of trouble was that I noticed that when brake is pressed, the dashboard battery gauge would drop a little. A few days later, the ABS warning light came on, then a few minutes later the battery completely died and had to be jumped (jumped easily). We have had the battery, alternator, and starter/cylinoid all checked. It was recommended that I have a diagnostic on the ABS system to see if something is draining the battery or trace the wiring (which can ultimately cost a bundle just to diagnose). Has anyone encountered this before? I don't want the repair shop to spend hours (and my $$) looking for the problem if I can guide them in the right direction. (It's happened to me before.) The vehicle is a 2000 Explorer with about 100,000 mi. I don't want to keep sinking tons of money in it.
STACYBASS
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic 114000 miles
I am having the same problem with my '98 Explorer.
The battery light illuminates while driving if the gas pedal is not engaged. The vehicle started after being dormant overnight, but during the brief period of driving, the veicle just shut down. Responded to jump, but only performed a few blocks before repeating the shut-down-while-driving process.
Also; the windows/locks not functioning, theft/ABS/airbag lights flashing, as well as intermittant beeping. Car also attempts to engage engine when key is out of ignition.
I have had the battery tested & it is presently at the repair shop.
I will post anything i find out as the mechanic lets me know.
-S
