2CarPros - Car Questions & Answers
2000 Ford Explorer Repair Question
Topics covered: Spark, Engine, Gas.
Asked on July 31, 2010
Won't start go figure
Engine Mechanical problem
2000 Ford Explorer 4 cyl Four Wheel Drive Automatic 325 miles
KK while i have a 2000 ford explorer won.t start it turns over but nothing i have got it started a couple times with alot of boosting and playing with the fuel shut off switch but now that"s not working there is spark and gas is getting to the engine what now??????????
Avatar Asked by Rocheleau69
Answer
Replied on July 31, 2010
If you have spark and fuel, it should run unless the timing is off or there is no compression.
I have to start with a couple simple questions. Is the spark to the plugs a good hot blue snapping park or is it more orange or white? Also, I understand you are getting fuel, but have you checked fuel pump pressure at the fuel rail? It could be too low or the regulator may be allowing all the fuel to return to the fuel tank.
Tiny Answered by Jacobandnickolas (expert)
57,475 answers provided
Replied on August 10, 2010
Sorry it took so long but i checked for spark it is blue and strong this fuel regulator not sure how to check this since i'm doing this in my driveway would replacing the feul line about a foot of it with the rubber gas line have anything to do withthis fuel pressure
Tiny Response from Rocheleau69
1 question asked
Replied on August 11, 2010
As long as you used high pressure hose, it shouldn't. Here is a how to for checking pressure. It is a video and directions. Check it and let me know what you find.
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
NOTE: You will need a gauge. Most parts stores will lend or rent them to you.
