Mechanics
NOT STARTING
1998 Ford Explorer
Engine Mechanical problem
1998 Ford Explorer 4 cyl Four Wheel Drive Automatic
at certian times my suv will not start turns over just find but dose not start let it set and it will start this has happen 3times in the past 2 months any sugestions, thanks joe
Joemurphy
August 11, 2008.
Will not start turns over just find but dose not start
To determine if its fuel or spark problem do below
Get a carb cleaner and spray into the carb or the throttle body on an EFI. Did it start and die? If not disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel problem, check the fuel pressure to rule out the fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil, distributor pick-up coil, ignition control module, cam and crank sensors-
Rasmataz
Aug 11, 2008.
U need to check for fuel pressure and spark when it doesn't start for you
check relays
check if security light on or blinking
AD
BMRFIXIT
Aug 11, 2008.
AD
