Mechanics
NO BRAKE LIGHTS
1998 Ford Explorer
Electrical problem
1998 Ford Explorer 6 cyl All Wheel Drive Automatic 127000 miles
I have no rear brake lights (including the upper). Also no turn signal. The light comes on when I turn on the lights. Fuses are good (I checked them all). Lamps are good. I suspect a wiring harness problem but have no schematic.
Lemon123456789
August 12, 2008.
No brake lights or turn signals?
Do front turn signals work? Rear neither?
I would suspect a bad brake on off switch or a faulty turn signal switch.
Get both at a junk yard as the turn signal switch is a expensive item to buy new.
Blackop555
Aug 12, 2008.
AD
