1998 Ford Explorer
Shakes or Wobbles problem
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic
I just had the wheel bearing replaced and while im driving and ge up to 60mph it shakes quite abit is there something wrong?
second question. Where is the 4x4 computer in the explorer? Think it needs replaced but have no idea where it is.
thank you for your time
lori boozer
Lori boozer
September 30, 2010.
The shaking should not happen. Has this just started since they replaced the bearings?
As far as the 4wd computer, there isn't one just for the 4wd. There is an actuator on the transfer case that engages the 4wd. Is that what you are refering to?
