2CarPros - Car Questions & Answers
1998 Ford Explorer Repair Question
Topics covered: Dent, Corrosion, Four wheel drive.
Asked on March 1, 2010
1998 Ford Explorer Alternator
Electrical problem
1998 Ford Explorer 6 cyl Four Wheel Drive Automatic 98000 miles
White wire to allternator - Is this the ALT light.?Chewed through by rodents while stored- can we strip the wire & repair with wire caps?
Avatar Asked by StanRoss
Answer
Replied on March 1, 2010
If you can identify the wire where it goes-go for it, also see below charging system EWD
http://www.2carpros.com/forum/automotive_pictures/12900_charge_10.jpg
Tiny Answered by rasmataz
68 questions asked
To avoid corrosion, automotive wiring is repaired with solder, and heat shrink wraps with a wax sealant. The wire should be done that way.
http://www.2carpros.com/forum/automotive_pictures/62217_Tuarus_Alt_1.jpg
Tiny Answered by merlin2021 (expert)
18,145 answers provided
