Mechanics
TURN SIGNAL AND HAZARD NOT WORKING
1997 Ford Explorer
Electrical problem
1997 Ford Explorer 6 cyl Two Wheel Drive Automatic 170000 miles
REPLACED MULTI FUNK SWITCH. FIXED WIPERS BUT NOT TURN OR HAZARD. FLASHER GOOD. FUSE OK. WHAT NEXT? NO POWER WITH SWITCH ON TO BLUE WIRE. ALL GROUNDS LOOK GOOD AT FRT AND RR LIGHTS. PRIOR TO CHANGING MF SWITCH TURN SIGNALS WORKED BUT HUMMED.
WROBERTS
November 11, 2009.
Welcome to the forum, does the turn indicator on the dash work? Have you checked for voltage at any wiring circuits? There may be a multiwire connector under the dash close to steering column, for circuits going to and from the steering column. Lite blue wire carries voltage from turn/hazzard to multifunction switch. Lite green wire with white tracer carries voltage to left turn signal. Did you check for voltage and ground at the rear?
JDL
Nov 11, 2009.
AD
