1997 Ford Explorer
Transmission problem
1997 Ford Explorer V8 All Wheel Drive Automatic 152000 miles
i have a 97 eplorer V8 AWD, I had transsmission problems got a used one and had it put in. I got it back wednesday it is now saturday I noticed a couple drips of transmission fluid on the pavement at the gas station. I got more fluid put it in and there was a big puddle it all came out. When I look under my truck there is a protective plastic plate bolted under the radiator, and a flap on the to help protect objects getting up and hittin it. The transmission is leaking somewhere above that plate because it all pours out the side of the flap and bottom of the plate and not behind that plate under th transmission. Is this a line? The pump? Can I fix it easy myself?
February 28, 2009.
With out looking and checking it I have to say its more common for it to be the cooler line
should have it looked at
good luck
Feb 28, 2009.
