First, make sure the battery you installed is charged, the battery cables are clean and tight, and there is nothing that appears damaged on the wiring.
Next, you indicated that it cranked slow. Is the slow cranking what caused it to be hard to start?
As far as the one click, if it is coming from the starter, either we have a weak connection, weak battery, or the starter is bad. Here is a link that explains how to check the starter. You will need a helper. Note that the larger wire on the starter has 12v at all times, so be careful when working around it. The smaller wire on the starter show only have 12v when the key is turned to the start position. If you have 12v to the smaller wire and everything I mentioned to check is good, replace the starter motor.
Here is the link:
If you find the starter is bad, here is a link that explains in general how one is replaced:
Here are the directions specific to your vehicle for removal and replacement:
_____________________________
1995 Ford Truck Explorer 4WD V6-245 4.0L
Removal and Installation
Vehicle Starting and Charging Starting System Starter Motor Service and Repair Procedures Removal and Installation
REMOVAL AND INSTALLATION
WARNING: WHEN SERVICING STARTER MOTOR OR PERFORMING ANY MAINTENANCE IN THE AREA OF THE STARTER MOTOR, NOTE THE HEAVY GAUGE INPUT LEAD CONNECTED TO THE STARTER SOLENOID IS HOT AT ALL TIMES. MAKE SURE THE PROTECTIVE CAP IS INSTALLED OVER THE TERMINAL AND IS REPLACED AFTER SERVICE.
REMOVAL
1. Disconnect the battery ground cable.
2. Raise and support the vehicle.
3. Disconnect starter cable and push-on connector from starter solenoid.
CAUTION: When disconnecting hard-shell connector at S terminal, grasp the plastic shell and pull off. Do not pull on wire. Be careful to pull straight off to prevent damage to the connector and S terminal. If any part of the connection is damaged, replace the damaged components.
4. Remove upper bolt.
5. Remove lower bolt.
6. Remove the starter motor from the vehicle.
INSTALLATION
1. Position starter motor to engine and install upper and lower bolt finger-tight.
2. Tighten the upper bolt to 22-28 Nm (16-21 Lb-Ft).
3. Tighten the lower bolt to 22-28 Nm (16-21 Lb-Ft).
4. Connect connector on starter solenoid. Be careful to push straight on and make sure connector locks in position with a notable click or detent.
5. Install starter cable nut to terminal. Tighten to 11-13 Nm (91-122 Lb-In).
6. Replace red safety cap.
7. Lower vehicle to floor.
8. Connect battery ground cable.
NOTE: When the Powertrain Control Module (PCM) is disconnected and reconnected, some abnormal drive symptoms may occur while the powertrain control module relearns its adaptive strategy. The vehicle may need to be driven 16 km (10 miles) or more to relearn the strategy.
_____________________________________
Jul 1, 2020 at 9:11 PM
