Engine will not start up?
1994 FORD EXPLORER
170 MILES
ASHMOH28
I turn off the car. then when back to restart it. it will turn over but would not start. I put antifreeze in the reserve then it started. it felt hot and slow diving it. im waiting for it to cool down to check the radiator.
Jun 26, 2013 at 6:06 PM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
In your vehicle, you have a relay called an EEC (electronic engine control). It is located in the relay box under the hood. It is common for them to act up and do exactly what you described. When the problem happens, switch the EEC with another relay with the same part number and see if it starts. If it does, just replace the relay. When you turn the key to the on position without cranking the engine over can you hear the fuel pump run in the tank for 5 seconds?
Jun 26, 2013 at 6:56 PM
ASHMOH28
Thank you so much!!!! It worked :)
Jun 26, 2013 at 8:40 PM
  • 110,190 POSTS
I don't know what happened, but I just got your reply. I'm glad you got it going. Let us know if you have questions in the future.
Aug 10, 2013 at 9:29 PM
MRPETE
  • 6 POSTS
The car will turn over but not start. I replaced the battery yesterday, it started up right away. Went to start today and the car will turn over but not start. I do not here any power going to the fuel pump when the key is turned. I replaced the fuel relay and the eec power relay and still the same problem exists. Any thoughts
Dec 30, 2020 at 6:51 PM (Merged)
MASTERTECHTIM
  • 4,750 POSTS
remove the coil wire from the coil and crank it over and see if it sparks. if ok then reattach and check at the spark plug end. get back to us
MRPETE
  • 6 POSTS
On this car is the coil where the spark plug wires plug into, the box looking thing?
MASTERTECHTIM
  • 4,750 POSTS
yes
MRPETE
  • 6 POSTS
Is there any other way to check this I am by myself? Can I remove it and have it checked at local auto parts store? Would this have any effect on the fuel pump not getting power?
MASTERTECHTIM
  • 4,750 POSTS
no it cant be tested off the vehicle. when you turn the key to run does the check engine light illuminate? have you tried spraying starter fluid into intake to see if it will start?
MRPETE
  • 6 POSTS
The check engine light dosen't come on. I did get someone to help me, as far as I could tell there was no spark at the coil, I tried several times and with different plug wires?
MASTERTECHTIM
  • 4,750 POSTS
recheck your battery connections and fuse box under hood, i think we have a electrical problem. maybe a connector got loose when you replaced the battery.
UGLYLOVESME
  • 5 POSTS
Engine Mechanical problem
1994 Ford Explorer Two Wheel Drive Automatic 190000 miles
i replaced the battery,altnator,fuel filter, fuel pump an it wont start it cranks but wont start
MRPETE
  • 6 POSTS
let me ask you this, when I replaced the battery i replaced the neg cable conector, the old one was cracked almost all the way thru. I replaced the conector with a universal one- all i did was strip the four wires and clamp them all together, I rechecked them today thinking that may have been the problem, then as i stated earlier i replaced the fuel relay and the eec power relay. I had these symptoms years earlier when you the car wouldn't start and what was happening was the fuel pump wasn't getting power, when i turn on the key usually you hear the pump make a noise, I do not hear that noise at this time. the car turns over with no problem, just seems to not be getting fuel?
  • 110,190 POSTS
are you getting spark and fuel to the engine?
MRPETE
  • 6 POSTS
I fpund the problem, it was a conector that wasn't plugged in all the way. Thanks for your help
UGLYLOVESME
  • 5 POSTS
yes i am getting spark it actually started today an i drove about 5 miles an it started to sputter an died an wouldnt restart
MASTERTECHTIM
  • 4,750 POSTS
good job mrpete
  • 110,190 POSTS
It sounds like a fuel related problem. Have you rechecked to see if it is getting spark now that is doesn't start?
RKCLMBR_66
What connector was partially connected? Where was it located? I have a similar problem. If fuel pump runs 3 sec, will start, if not, no start. Very intermittant.
UGLYLOVESME
  • 5 POSTS
i said it gets spark after it dies it will start again if i let it sit for an hour or so
MASTERTECHTIM
  • 4,750 POSTS
on the ground able there is a connector going from the smaller wire. if the connection is not good and clean then it will cause many intermittent problems. yuo can cut out connector and wire in a splice connector and eliminate the connector
  • 110,190 POSTS
If it continues to get spark, then it has to be fuel related. You also mentioned you have to wait an hour after it dies for it to restart. During that time, do you have a good hot blue snapping spark and proper fuel pressure. If the spark is good, then it must be fuel related, or the crank sensor is cutting out and causing it to do this.
UGLYLOVESME
  • 5 POSTS
could it have anything to do with the ignition? sometime if i hold the key in a wierd position after the vehicle is running it will drive fine but if i let go it dies. kinda weird
  • 110,190 POSTS
Yes, if the ignition switch is bad, loose, or out of adjustment, it could cause this.
UGLYLOVESME
  • 5 POSTS
should i first checj the ignition switch or the key cylander?
  • 110,190 POSTS
The tumbler is may not be moving the ignition switch, but I would say the switch first first.
TAYLORMADE9998
When I drive my car a short distance less then 5 miles or a long distance over 10 miles it is fine. But if I drive it between 5 to 10 miles then shut it off when I go to restart it it won't start. It trys turning over and all but it wont. After waiting about 5 minutes it will again start. Do you know whats wrong?
MASTERTECHTIM
  • 4,750 POSTS
your being too vague. does the engine turn over but not start? or does the engine fail to turn over?
Dec 30, 2020 at 6:52 PM (Merged)
TTRAN
  • 45 POSTS
This is easy.
You properly have a dirty air intake.
Try this procedure.
Go to an autozone to purchase an inject and throttle cleaner. It usually comes with a spray bottle.
First, you need to uncrew and remove the intake duck (the rubber duck that connect between the air filter housing and the throttle valve housing).
Second, spray the bottle into the throttle valve housing, try to push the throttle open where the tension cable connect to the gas pedal. Spray in it and clean all the dirt and crease. Spray 4 or 5 times and clean it each time after you spay. All the dirt and crease you could not clean will be push down to the muffler. After you spray, clean the intake with a damp cloth carefully and put the rubber duck back together.
Finally, let it sits for half of an hour then start the engine. It will start and hola, the problem will never come back again.
I have the same problem as yours. Some one from other forum show me how to do this. The problem seems to be fixed since. Oh, and the vehicle seems to run smooth too.
Good luck,
Tony
RED-I
  • 10 POSTS
Well there was recently floods here in florida and i drove through some everything seemed fine but just recently my truck is having problems starting. sometimes it will start first time other times it takes 10-20 turns of the key the battery is fine and i don't understand it... it varys on how long it takes to start i was thinking maybe the spark plugs but maybe it could be something else? where are the spark plugs located. I dont have alot of money and this will kill me if it dies on me any help would be greatly appreciated
Dec 30, 2020 at 6:53 PM (Merged)
BLACKOP555
  • 10,386 POSTS
what do you mean when you say it wont start?
do you mean crank just not fire over and run? not crank? need to know dependent on the problem the answers are completely black and white.
RED-I
  • 10 POSTS
when it cranks it starts perfectly most times i turn the key its like theres no kick to the engine its not cranking other times it starts up fine and other times i hold the key turned over for 2 or 3 seconds then it cranks and starts perfectly
RED-I
  • 10 POSTS
i have a feeling its the spark plugs because if it was the starter or altinator it wouldnt be so random and it fires perfectly "when" it cranks ranging from 1 to 20 times so i think that rules out the fuel pump im just scared im gonna burn the starter out when its takin 20 turns of the key to make it crank..is it possible they were damaged from drivin through the water? if so i was looking for them under the hood but i couldnt see them
BLACKOP555
  • 10,386 POSTS
you say it wont crank sometimes and you have to keep turning it before it will crank?
if thats the case the starter isnt engaging and turning the engine the typical cranking noise before it fires.
is that true that there is no cranking untill you turn the key enough?
RED-I
  • 10 POSTS
exactly but when u say "enough" it varys sometimes it takes longer then others...othertimes it happens first try but thats like 1 in 4 chance
RED-I
  • 10 POSTS
do you know what the problem is? id really appreciate any help or any way to fix it as cheeply as possible i mean my worst fear is it wont start when i have my daughter in there i cant even afford a cell phone bill ....or it evenetually just wont start at all and i have no way to get to work
BLACKOP555
  • 10,386 POSTS
sounds like its a issue with the starter or relay.
apply direct battery power to the starter to see if it turns, or if you have to keep reapplying the power till it eventually cranks.
RED-I
  • 10 POSTS
Ok. I have tested the alternator the battery and the starter all are in good working order. Yet i'm still having the same problems. the starter will not crank. sometimes it takes 1 turn othertimes it takes 5 minutes . Please help what else could the problems be and how can i test them so i can eliminate them..
BLACKOP555
  • 10,386 POSTS
check the starter relay/solenoid if not already checked.
then next i would check the neutral safety swithc, try starting in neutral, any thing better?
RED-I
  • 10 POSTS
the starter is fine i took it off the truck and took it to autozone.... how do i test the solenoid ? and i just tried starting it in nutreal it makes no difference
