1994 Ford Explorer
Transmission problem
1994 Ford Explorer 6 cyl Four Wheel Drive Automatic
I drive a 1994 4wd Ford Explorer. In the past month or so it has been acting weird, sometimes I will be driving and it will just die and lock up, wheel, brakes, everything. It usually takes about 15 to 20 minutes for it to start back up and then it drives fine. It does this without warning and sometimes if it sits overnight it won't start the next morning. Also, I was driving it about a week or so ago and I stopped at a stoplight and when the light turned green it didn't want to move. The engine sounded normal but it just wouldn't go anywhere. It felt like I was in neutral. I got it to a lot, turned it off and tried again. It drove for about a hundred feet and it started again. It will drive fine in 2nd but not D. I don't know much about cars, was wondering if someone could point me in the right direction
August 11, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
