Mechanics
THERMOSTAT
1993 Ford Explorer
Engine Cooling problem
1993 Ford Explorer 6 cyl Two Wheel Drive Manual
i need to know where the thermostat is located on a 1993 Ford Explorer
Steveshack
December 17, 2008.
If you follow the top rad hose from the rad to the engine block, you will find a metal housing. Inside of this housing is the thermostat. Should be held in place by 3 bolts.
Bobo234
Dec 19, 2008.
