I have a explorer that won't start. I was driving about 25 miles and hr and it just stooped running. I tried to restart it but it won't run. When i got it home i checked for fire and there is no fire. So then i checked for fuel and there is no fuel pressure. The relay comes on but the pump don't run. It cranks fine. I replaced the ignition coil pack, crank sensor, and the computer that is in the passenger side kick panel. I still have no fire or fuel. I have checked every fuse. The mini and maxi fuses. I also checked the fuel shut off switch and its fine. What is the matter with this crazy clown car. I have been working on cars for 10 years and i have never had this issue.
Jan 11, 2010 at 6:28 PM
