no starter operation is not working why?
1993 FORD EXPLORER
145,000 MILES • 6 CYL • 4WD • AUTOMATIC
MARKV1234
my 93 explorer will not start infact it doesn't crank at all. I hear the fuel pump when I turn the key but nothing else.
Mar 18, 2010 at 7:32 AM
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
Have a helper turn the key to the start position while you check for voltage to the smaller wire at the starter. It should have 12+ volts. If it does, chances are the starter is bad. These guides can help us fix it
and
Mar 22, 2010 at 10:42 AM
BEEFCAKE3883
hello. my car would not start the other morning so i removed the battery and took it to be tested. battery is good. i cleaned the terminals and put the battery back in. still just getting a single click when i turn the key. tried bridging the posts on the solenoid with a screwdriver and still just the one click. could it be the actual battery cables? or the starter? or something else? thanks for any answers.
Dec 31, 2020 at 9:28 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Hello
Thanks for the donation
How are the headlights, radio..etc..?
You say you jumpered the starter solenoid and it still clicked only once. I would suggest removing the starter and having it tested. Suspect faulty starter. It may be possible to have starter rebuilt rather than buying a new starter if you choose to do so.
Thanks for using 2CarPros.com!
BEEFCAKE3883
thanks ..
radio, lights, etc. work .. the batt cables arent in the best shape. could that be the problem? or is starter make more sense?
BLUELIGHTNIN6
  • 16,542 POSTS
Normally when the battery is at fault it will cause a rapid clicking noise from the starter solenoid rather than just one click. However since you state the cables are in poor shape it may be that the connection at the starter is poor causing the starter not to work properly. Go ahead and replace the cables. It is a cheap and effective solution if it does work. If it is not the problem you can remove the starter and most part stores will test the starter free of charge for you.
Thanks for using 2CarPros.com !
LJOBUBBA
I went to leave work last night and it wouldn't start. my boyfriend thought my solenoid was bad. so today we replaced it and it still did the same thing no starter noise (like i've heard from past vehicles) no clicking noise (like battery) and all lights come on and power windows work, radio works. Please help!!!
KNIGHTSCBR
  • 20 POSTS
check to make sure there is 12V on the wire that goes to your solnoid when the key is in the start position, or try to jump your slnoid with a screwdriver, with key on
DSKOORB
  • 7 POSTS
I replaced the ignition relay and it clicks when I turn the key, however, the starter won't turn over. I'm considering pulling and taking it for testing. It worked fine until I had the idler and tension pulleys replaced. Any thoughts as to what else might be?
Thanks in advance for your help.
OBXAUTOMEDIC
  • 3,711 POSTS
Did you replace the Ignition Relay or the Starter Relay?
If replace ignition relay and you get a clicking under hood in area of battery then I would replace the Starter Relay here is a pic of what to look for...
DSKOORB
  • 7 POSTS
The item you sent a photo of is what I replaced. It does click when I turn the key to start.
What would be the next thing to check?
Thanks for your help!
OBXAUTOMEDIC
  • 3,711 POSTS
Try jump starting it. If it will start then most likely its your battery and you should take it by your local parts store and have them test it.
DSKOORB
  • 7 POSTS
Did that. I've checked all the fuses, metered the correct voltage at the coil pack, and all cables are intact.
I'm putting it up on jack stands now and will pull the starter to have it tested. Does this seem prudent or should I just have to towed to a shop. Just trying to save some money.
Thanks again.
Dave
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, if the relay is clicking the try this....
Jump the 2 big terminals using a screwdriver, if the engine turns over then you may have gotten a defective relay.
DSKOORB
  • 7 POSTS
Which terminals, on the relay or the starter?
OBXAUTOMEDIC
  • 3,711 POSTS
The 2 Large terminals on the relay by the battery.
With the relay clicking it's an indication the there is either not enough power getting throught it, A bad Relay or bad cable.
DSKOORB
  • 7 POSTS
I will try it. I have to get to my friends house to do so, it's in his garage. I'll let you know what happens!
Thanks again for your time and help.
2CP-ARCHIVES
  • 4,540 POSTS
it wont start when i turn the ignition. it clicks like its a dead battery but i took the battery in to get it checked and its fine. plus when it first started doing this i had been driving all day and i was at the store. so i asked a person for a jump and it still didn't start. when i went to the auto store and explained the problem i was having to them they suggested that it may be the starter. now i have a leak coming out to the power steering pump, and its dripping directly onto the starter and all the connections on the starter. they are all tightly connected to the starter. but could this be the problem. also the click i hear when i try to start it, isn't coming from the starter. its coming from the side wall right next to the battery. there is a fuse box and the starter solenoid, and this is where the clicking noise is coming from both the fuse box and solenoid. please help answer the question i feel its something stupid and simple. but beyond my knowledge.
OBXAUTOMEDIC
  • 3,711 POSTS
Ok, if it doesn't turn over then you should go ahead and remove the starter and take it in for testing.
CARADIODOC
  • 34,309 POSTS
There's three things that commonly happen with Ford starter systems. First check the connections on that starter relay near the battery. The large copper nuts often work loose. Next, measure the voltage on the large cable right at the starter while a helper turns the ignition switch to "crank". If it goes real low, suspect corroded strands of wire under the insulation where you can't see it, right at that end. Third, oil or power steering fluid that gets inside the starter will deteriorate the brushes and make them crumble. If that is the case, the voltage on the large cable will still be there but the motor won't spin.
DSKOORB
  • 7 POSTS
I pulled the starter assembly off and took it to be tested. It tested okay. Perplexed, I cleaned it up and re-installed it. When I pulled if off, I noticed that the small wire in the bundle that attached to the solenoid was not connected. When I re-installed it, I connected that small wire (it was on a spade terminal), and it started right up.
Thanks for your help.
OBXAUTOMEDIC
  • 3,711 POSTS
Great Job!!
JAMES HIXON
I was driving it before and it's running good and when I went to start it clicking noise. I even checked the battery and it's good.
Good morning.
What is the battery voltage?
This could be either dirty battery cables or a bad starter if the battery checks out.
Can you upload a video of the noise when you try to start?
JAMES HIXON
Thank you so much for your help.
  • 54,350 POSTS
Dec 31, 2020 at 9:29 AM (Merged)
JAMES HIXON
Thanks for your help. I found out the problem it's my starter.
  • 54,350 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
CARJBART
Started a month ago problem persisted so we replace the battery. Ran foe several weeks ust fine but now its doing it again. What is is doing is:
Sometimes you get in and turn the key and nothing happens. Other times it starts just fine. Yesterday it finally came to a head. It would not start so friend jumped the vehicle and we drove it to their house.
Car would not start after that, not even with a jump.
Replaced solenoid next to the battery, did nothing. That alternator guage inside the car show positive like it should, when the car is running.
  • 110,190 POSTS
Hi
I need you to test something. If the starter isn't working, have a helper turn the key to the start position while you check for 12 volts at the smaller wire at the starter. Let me know what you find. This will tell me if the starter is the problem or we need to go to the relay. Also, make sure the ground wire to the engine block is tight and clean.
ACHAZ71
shut the car off and it would not start, it just clicked. replaced the starter cylinoyd on the fender well. stil got the click, not like a low battery just a single click. removed the starter and had it tested at the parts store. it tested good, they tested it three times. what else could it be?
CARADIODOC
  • 34,309 POSTS
Real common problem is corroded battery cables but you have to look under the insulation near the ends. The next step is to measure the voltages at various places while the solenoid is activated, either with a helper turning the ignition switch or you can run a jumper from the battery positive to the small terminal on the solenoid.
JMAN69
yesterday, I stopped to get gas and left the radio on for my kids. When I finished with the gas, I went to start the truck and I just hear one "click". Keep trying and that's all I get, the one "click". I towed it back home and still the same, "click". So I get up this morning and get ready to start pulling the battery, starter, alternator, etc to have them checked. I think I'll try starting it again, and what do you know, it starts right up like nothing was ever wrong. I've only had the truck for a few weeks but it's run fine other than eating up the gas. So, what do you think is the cause? Now I'm worried to drive anywhere in fear that it might not start once I get somewhere. Thanks.
Load test the battery and make sure its cleaned and tight both ends of cables. Could also be a problem with the start circuit-ignition switch, starter relay,starter and back lamp switch, and starter itself.
https://images.2carpros.com/forum/automotive_pictures/12900_st1_9.jpg
LKS44
When I went to start my car, it won't start. I have a new battery. All I hear is a clicking noise. What could be wrong?
ARTMANG
  • 61 POSTS
hello,well first make sure the battery connections r nice n tight.then check the ignition relay solenoid or also called starter relay.its close to your battery and one of your battery cables go connected to it u cant miss it,its brown round and has two battery size cables connected and one thin wire on the bottom.to chek it just put the ignition key in on position and leave it like that.now with a screw driver make contact on the 2 big wires wich is power and negative.not the small one dont touch that one .with the screw driver just touch one of the wires or screws and at same time contact the other and it will make ur engine turn.with key in on position if the engine fires up and starts then u will need to buy a new solenoid.if not chek ur starter .hope it works out for u. by the way always have ur parking brakes on for safety.
YANKEEBANKKEE
i have a 91 ford exploper and when i go to start it it just makes one click and will not turn over i changed the cylinoid out and it still does the same thing what else could it be
BMRFIXIT
  • 19,053 POSTS
check starter
Ensure battery is fully charged and in good condition. Ensure battery cables and connections are in good condition. Measure voltage at starter solenoid battery cable terminal. If voltage is less than 12 volts, recheck battery cables and connections.
Service as necessary.
Connect one lead of remote starter switch to starter solenoid battery cable terminal. Connect other lead to "S" terminal on starter solenoid
ANGELFIRE09
i have a 91 explorer and when i try to start it makes just one click?
  • 110,190 POSTS
I would start by making sure the battery terminals are clean and tight. Also, make sure the ground that goes from the battery to the engine block is clean and tight. Finally, have you had the battery checked? If everything I mentioned above looks good, remove the battery and have it load tested at a parts store. Most will do it for free. If it is good, let me know and I will explaine how to check the starter.
JOSHUAK
Engine Mechanical problem
1991 Ford Explorer 6 cyl Four Wheel Drive Manual
I just got a 91 Explorer Sport 4x4 5speed 4.0L from my brother today. When he bought the vechicle someone put a bronco II transmission/flywheel/clutch assembly in the vehicle. He was having starter problems with the teeth lining up. He went and put a new flywheel/clutch assembly, a rebuilt Explorer trans. new driveshaft, new clutch master cylinder, new correct starter (correct by the parts store) and had a trans. shop do all of this work. Everything was great and all of a sudden the starter started to grind when trying to start the suv. He replaced the starter 3 times and they all seemed to work great for about 2-3 weeks and then it would start to grind again.
My question is, I now have the suv and do not want to keep sinking money into starters every few weeks. Does anyone know what could be wrong with this explorer? I have not taken the time to check the starter or flywheel yet because it is raining outside.
Thanks!
