Mechanics
WONT START
1991 Ford Explorer
Electrical problem
1991 Ford Explorer 6 cyl Four Wheel Drive Automatic 130000 miles
91 explorer. Sitting for a year, was running with no probs when parked. Charged battery put in five gallons of gas. Engine just turns over wont fire. Checked to hear fuel pump. Tried starting fluid. Checd to see if fuse blown. Still wont fire
Curtiss-hill
June 7, 2010.
Sounds like no spark it should fire up when you use the start fluid for a sec or 2
No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs, coil's resistances, distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
Rasmataz
Jun 7, 2010.
AD
