I was told that the dirty door sensors are causing the vehicle to think that the door is ajar. How do I fix this problem or eliminate the noise alert, it is non-stop.
Do you
have the same problem?
Monday, August 9th, 2010 AT 8:09 PM
MECHANIC
The switch is part of the latch assembly on your vehicle. You need to remove the door panel to access it. At that point you can check to see if the switch is bad or dirty. Here are diagrams below to help you change it out. Check out the diagrams (Below). Please let us know what you find.
Images (Click to make bigger)
SPONSORED LINKS
Tuesday, August 10th, 2010 AT 11:25 PM
MBOICE
MEMBER
You said that the latch is part of the door assembly, the ford mechanic said it is generally dirty and there is no way to really fix it. Is there a way to deactivate the door ajar alert? Maybe one of the fuses?
Saturday, August 14th, 2010 AT 7:15 PM
MECHANIC
There is a fuse, but it will disable other things too. As far as the switch, is there a reason he can't clean it?
Sunday, August 15th, 2010 AT 12:14 AM
SVARWIG
MEMBER
I have had this problem for several years. This post helped me fix it I had to get a latch cost me $98.00 all fixed I love this site.
Monday, October 4th, 2010 AT 8:39 AM
MECHANIC
Nice work, we are here to help, please use 2CarPros anytime.
SPONSORED LINKS
Monday, October 4th, 2010 AT 10:18 AM
MRDUNN
MEMBER
1 POST
2004 FORD EXPEDITION
V8
4WD
AUTOMATIC
135,620 MILES
Door Ajar light won't go off. And it's effecting my air suspension. I checked all the doors and still won't go off.
Thursday, August 8th, 2019 AT 12:48 PM
(Merged)
BLUELIGHTNIN6
MECHANIC
Stuck or faulty door ajar switch most likely culprit. Lubricate all door latches including rear hatch with WD40 to see if it will loosen the switch.
(Merged)
FRYMAS
MEMBER
1 POST
2003 FORD EXPEDITION
V8
4WD
AUTOMATIC
67,000 MILES
I have intermitant "door ajar" signal when all doors are fully closed. How do I fix problem?
Thank you,
Frank Rymas
(Merged)
DAVE H
MECHANIC
Spray a lubricant into the door lock mechanism and open and close the door a few times. To lubricate the door ajar switch
(Merged)
DHANNER
MEMBER
5 CYL
156,000 MILES
I have a 2003 Ford Expedition and the door ajar light won't go off. All the doors are shut but the lights won't go off. Can you please help!
(Merged)
BMRFIXIT
MECHANIC
Starting with driver door use penetrating oil spray door latch
Open and close door few times and spray again
Repeat on all doors
(Merged)
DHANNER
MEMBER
I've tried Wd40 and Liquid Wrench neither one worked! Is there a switch or something I can replace?
SPONSORED LINKS
(Merged)
BMRFIXIT
MECHANIC
Yes switch is in door latch
If you have an access to a scanner, check BCM codes
Or data it should show which switch is at fault
99% of the time WD40 or penetrating oil worked for us
(Merged)
BILLY2005
MEMBER
1 POST
V8
4WD
AUTOMATIC
87,000 MILES
All doors are closed tightly how ever at times the door ajar will keep going on and off just like a door was being opened and closed.
(Merged)
BLUELIGHTNIN6
MECHANIC
You have a sticking door ajar switch. There is a switch in each door, as well as a switch in the rear hatch and rear glass hatch. Try lubricating the door latches with WD40.
(Merged)
RBERGEE
MEMBER
1 POST
V8
4WD
AUTOMATIC
129,000 MILES
About 3 months ago the door ajar light on the dash would stay on even after checking all doors and windows. After a couple of days it would go off. Then it got progressively quicker between light on and light off. Now it is continuous for the last 2 weeks. I had my oil changed and they checked the battery and said it was bad, only 2 1/2 months between oil changes when it was good. Is this draining the battery and can I check to see if one of the door sensors is working and replace it my self? Thanks for your response, Rahn Bergee
(Merged)
MECHANIC
The switch is part of the door latch. As far as checking, you need to check if there is a draw on the battery after everything is off. Here is a how to for checking. Check it and let me know what you find. NOTE: If there is a draw, remove one fuse at a time to determine what circuit the problem is coming from.
I am having a problem with mt Door Ajar and my interior Lights will not go off. What do I do and where do I start?
(Merged)
BLUELIGHTNIN6
MECHANIC
This is a common issue with the newer model Ford trucks and SUVs. One of the door ajar switches, 1 located in each of the 4 side doors as well as 1 in the rear hatch, has failed. You will have to test each switch to see which one needs replaced.
