Power window?
ERIC KARCHER
  • 2000 FORD EXPEDITION
  • V8
  • 145,000 MILES
The driver window won't go down on 2000 ford expedition.I can hear a clicking near fuse panel.
Do you
have the same problem?
Wednesday, January 12th, 2011 AT 5:05 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,554 POSTS
It sounds like you have a window motor that is going out. Here is a guide to help you see if it is getting power and a wiring diagram (below) so you can see what you are doing. It could also be the one touch relay. Here is a guide to help you
and
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Saturday, July 29th, 2017 AT 2:45 PM
DARRENK
  • 7 POSTS
Interior problem V8 Four Wheel Drive Automatic 90000 miles
The driver side window seems to be off the track and dislodged. The window slides within the door. How do you reattach or reinstall the window in the track/regulator?
Tuesday, July 21st, 2020 AT 5:45 PM (Merged)
KEN L
  • 42,554 POSTS
The window gets off track because the window regulator is bad and needs to be replaced. Here is a guide to help you get an idea of what you are in for when doing the job.
https://www.2carpros.com/articles/how-to-check-and-replace-a-electric-power-window-motor
Here are diagrams of what it will be like for your car (below)
Cheers, Ken
MOTHERLAND
  • 6 CYL
  • AWD
  • 131,561 MILES
The window is stuck and can't go up or down and there is a crancking noise everytime I tried to close the window. The prolem is on the driver's side.
MERLIN2021
  • 17,250 POSTS
https://www.2carpros.com/how_to/power_window.htm
Gear on the motor may be striped, or a bolt fell out allowing the motor to loose grear tooth contact.
HUCK572
Interior problem
2000 Ford Expedition V8 All Wheel Drive Automatic
driver's side window goes down ok but comes up off track. I have to raise it a few inches, pull it to the reare and so on until it is up. Not completely up aligned.
  • 108,014 POSTS
Have you removed the door panel to check the linkage?
JUSLIKEME2
  • 1999 FORD EXPEDITION
  • V8
  • AWD
  • 150,000 MILES
Is there a way that I can get my window back on track without taking it to a mechanic. And how can I get the panel off?
  • 108,014 POSTS
Hi:
The panel is held on by a few screws and plastic clips you can't see until removed. Remove all screws, and then you will pull and the clips will pop off too. That way you will have access to the window track.
TIMHESS79
  • 5.7L
  • V8
  • 4WD
  • 150,000 MILES
Driver's window does not always work. I can hear a click sound coming from the relay box inside when I push the window down button. Can even feel the click if I touch the relays when I hit the button. All the relays and fuses seam to be good. I have taken the door apart and everything mechanically seams to be fine. While working on it last night the interior and running board lights began to flash on and off slowly and I could hear that clicking as they flashed, ran the battery dead while trying to diagnose.
HMAC300
  • 48,601 POSTS
It may be the motor, slam the door hard and see if it works. Or the wires are broken between door and jamb. Have a mechanic scan for codes for the flashing lights may be a module problem.
TIMHESS79
Think I have got it figured out. GEM, I just bypassed the auto down option. Window works fine, just no double click and release allowing the window to go down all the way. Have to hold the button until it is down. It is terrible I tell you. There are so many other things I could be doing with that hand while my window rolls down by itself, flipping the bird, shaking my fist at people, picking up loose change. It is ungodly I say!
  • 31,938 POSTS
Open the door and take the protective sleeve off the loon from the door to the pillar, wiggle each wire and see if there is a damaged wire a part broken wire will often cause this type of problem.
JESUSCHAIRES
Hi my 1999 expedition has gone through at least 3 new batteries in one month. Also I can put my windows down without the key being put forward or backwards. Then my dashboard light do not work. What could be the problem?
CARADIODOC
  • 33,699 POSTS
Need a lot more detail than that on the battery problem. How did they fail? Did they just go dead in a few days? Have you tested the charging system? What were you told when you returned the batteries? What was the symptom or problem?
If your windows will operate with the ignition switch turned off, there is likely a related drain on the battery which will cause it to run down. You don't replace the battery for that. You use a battery charger to recharge it.
The dash light problem could be nothing more than a blown fuse. They often blow from the surge when reconnecting the battery.
JESUSCHAIRES
I do have a audio system in the truck but the batterys are new and only last 2 weeks and I go every time to exchange it and the people at autozone tell me something is draining my battery but I dont know what it is. They always tell me that the battery is bad when I go. The truck also has a new alternator and a new starter.
CARADIODOC
  • 33,699 POSTS
What happens after two weeks? Does the battery fail to crank the engine? Is it totally dead? To be properly tested at the auto parts store, it has to be slowly charged, then tested under load to see how much current it can deliver while maintaining a specified voltage.
The place to start is by testing the charging system. The first part you can do yourself with a digital voltmeter at the battery. It will read 12.6 volts if the battery is fully-charged. If you find it's around 12.2 volts, the battery is okay but it's discharged. If it's around 11 volts or less, it has a shorted cell. That would not be common on a newer battery.
Next, measure the battery voltage again while the engine is running. It must be between 13.75 and 14.75 volts. If that is okay, the rest of the tests must be done with a professional load tester to see how much current the generator can deliver. If it has one bad internal diode of the six, you will only get exactly one third of its rated output, and that's not enough to meet the demands of the electrical system under all conditions. The battery will have to make up the difference until it runs down. That could take from a couple of days to a month or more, depending on how much you use the heater fan, light, wipers, etc. Besides the low output current, "ripple" voltage will be very high when the generator has one bad diode.
I have to go out of town for a day. I'll check back tomorrow night to see if you had the load test performed and what the results were.
DAVIDSTEWART8
  • V8
  • 4WD
  • 104,000 MILES
This has happened twice in last year I put drivers window down and go to run it back up nothing, wait about two hours go back and it will go up I can hear a relay trying to work behind fuse cover
LEGITIMATE007
  • 5,121 POSTS
Sounds like either the relay is going bad or its time to replace the motor, it can only be one of the two, in the process you may want to check the switch too, most times you can go to the salvage yard and get those parts next for next to nothing, who will know besides us. Lol
JHUSTON
  • 1998 FORD EXPEDITION
  • V8
My window wont roll down but when I push the switch it clicks
