Seats are not working can I get a wiring diagram please?
ANONYMOUS
  • 2006 FORD EXPEDITION
  • 96,500 MILES
How can I check fuse for seat Warmer's?
Wednesday, October 24th, 2012 AT 11:02 PM
Sounds like its not heating up-correct if so check fuse below if okay have the climate controlled seat module checked/tested at under driver's seat -see pic below
Thursday, October 25th, 2012 AT 1:10 AM
MMMERED
  • 2005 FORD EXPEDITION
  • V8
  • 70,000 MILES
I purchased a new rear captain seat arm rest from Ford parts and don't know how to install it? I thought I'd just have to push it on and the metal clip would snap but it doesn't stay on and is too loose. How do I install the arm rest? The fitting is a hard plastic circular hole which the bolt fits into but I can't figure out how to keep it tight.
Ford Part number #4L1Z7867112AAA
Monday, December 14th, 2020 AT 8:54 AM (Merged)
MERLIN2021
  • 17,250 POSTS
Removal and Installation 1. To access the armrest locking metal clip, pull the armrest material back on the top side of the armrest for access to the release clip. Fig. 273: Pushing Release Button At Hinge Point Courtesy of FORD MOTOR CO. 2. Use a tool such as a flat-bladed screwdriver to push the release button at the hinge point. The clip will release and the armrest will slide off the pin. 3. To install, reverse the removal procedure. Ã Â Â To install the armrest, push the release button and slide the armrest on the pin. CAUTION: To remove armrests, do not pull them off with force. The locking metal clip will be damaged and a new armrest will need to be installed. NOTE: Armrest removed to show detail of release button mechanism. CAUTION: To install armrests, do not push them on with force. The locking metal clip will be damaged and a new armrest will need to be installed.
3/11/2010 ...
https://www.2carpros.com/forum/automotive_pictures/62217_Armrest_1.jpg
THEKID33
  • 2004 FORD EXPEDITION
  • V8
  • 4WD
  • 85,000 MILES
Problem with the drivers heated seat. Passenger side works fine. The drivers seat worked up to Dec. 2009.
When turning on the seat, heat switch lights for 2-4 seconds and then turns off. Any sugestions and do you have the wiring diagram for this?
Thanks Jim
  • 108,117 POSTS
Jim:
Chances are the switch is bad. What you need to do is check to see if there is power going to and from the switch when the light goes out. If there was a short, it would blow a fuse. Something tells me the switch can't handle the load and is disconnecting itself.
JDWALTON
  • 2003 FORD EXPEDITION
  • V8
  • 120,000 MILES
I had this problem a year ago and Ford said it was a short in the wire and they replaced the wiring harness. It was an invasive procedure (according to them) and it was $400.
Q#1:Can I replace this harness myself? I dont mind buying repair manual and tackling this. I just dont know whats involved to get the harness out. I installed my nav unit (avic-d3) and know enough to be dangerous.
Q#2: Also, is there a manual way of moving the seats up/down?
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,787 POSTS
I think you can just fix the old harness here is the guide to help and the seat wiring diagrams so you can see how the system works. Also there are two relays and three fuses that need to be checked as well,
and
and
JCLARK0622
  • 6 POSTS
I have a 2003 Ford Expedition. The driver side power seat will not move back or forth but will move up or down. I do hear a clicking noise when I try to move it back or forth what could this be?
  • 108,117 POSTS
Have you checked the switch to see if power is present both in and out?
JCLARK0622
  • 6 POSTS
How do you check that?
  • 108,117 POSTS
Remove the switch. Behind it will be wiring. One of the wires should be hot all the time. With a test light, check if power goes out the other wires when you place the switch in different positions.
JCLARK0622
  • 6 POSTS
Thanks I will try that
  • 108,117 POSTS
Let me know what you find.
KEN L
  • 42,787 POSTS
You can't move it manually, it sounds like the drive gear for the seat track is stripped or the motor drive gear is missing its teeth. Here is how you can fix it in the diagrams below. Check out the diagrams (below). Please let us know what happens.
CHRIS DUFFY
  • 5.4L
  • V8
  • 4WD
  • 229,000 MILES
I took this SUV in on trade and found out the above mentioned issue. I was wandering if a relay or something is the reason for that? And also the interior lights don't come on when you open the door and the radio keeps playing even after you shut the car off and open the door. Any help would be greatly appreciated. Thanks
  • 108,117 POSTS
The components you mentioned are on different circuits, so I don't feel it is one thing causing all problems. Have you checked the main fuses under the hood?
Here are a few links you may find helpful:
___________________________________
Other than a fuse issue, it could be related to the body control module. However, I suggest checking fuses first.
CHRIS DUFFY
Where is the fuse box under the hood? I haven't been able to find it anywhere.
I was just running through open questions and can provide what you requested. Joe is on the right path that if these are related then you may have a body control issue, however, I would run through these as he suggested.
Here are all your fuse boxes:
DOLPHINRICH
  • 2001 FORD EXPEDITION
  • V8
  • 100,000 MILES
My drivers side power seat will no longer move forward or backward. It is currently stuck at the midway position, which is very uncomfortable.
Is there a manual way of moving the seat backward? I was hoping there may be some sort of latch, that allows it to move freely, instead of by the motor.
Please let me know. Thank you in advance.
BMRFIXIT
  • 19,053 POSTS
It sounds like you have a switch for the seat that is out. But to be sure here is the wiring diagram and a guide to confirm the problem. Also make sure the fuse is good.
https://www.2carpros.com/articles/seat-position-switch-replacement
Please run down this guide and report back
Cheers
