When I try to start my expedition it will crank but it won't start. I have determined that it is a fuel problem since there isn't any fuel at the rail. I have replaced the fuel filter, fuel pump, fuel pump driver module, crank position sensor, and both cam position sensors. I have also pulled the central junction box and checked the built in fuel pump relay to see if it was bad and it wasn't. What else should I be doing to get fuel to the engine
Sunday, March 24th, 2019 AT 10:49 AM
(Merged)
