fuel filter
2000 FORD EXCURSION
198,000 MILES • V10 • 4WD • AUTOMATIC
how to change a fuel filter on a 2000 ford excursion
Jan 29, 2011 at 3:20 PM
BIG TEXAN
Hello
The fuel filter is located along the LH frame rail. Here is a guide to help walk you through the steps with diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Jan 31, 2011 at 10:54 PM
PAMARNOLD
could you tell me where the fuel filter is and how to change it?
Apr 28, 2020 at 1:22 PM (Merged)
  • CAR REPAIR CONTRIBUTOR
  • 110,190 POSTS
I believe the filter is either along the frame rail or near the fuel tank on a 2000. Based on which filter you have, the fuel lines will either unbolt or it will have a quick connect. The quick connect requires that you push in on the fitting and remove a plastic clip to remove the line.
If you have trouble, let me know.
