Mechanics
COOLING FAN IS NOT WORKING
1996 Ford Escort
Electrical problem
1996 Ford Escort 4 cyl 104000 miles
My cooling fan stopped working. I can run a hot wire to terminals on plug and fan works. I have 12. Volts on the fuse and the fuse is not blown. What do I need to look for next?Where would the relays be located?
Mullism
May 4, 2010.
It could be a relay or a bad temp sensor. Check the relay first.
AD
