1993 Ford Escort
1993 Ford Escort 4 cyl Front Wheel Drive Manual 188000 miles
please help me!
i have a '93 escort. 1.9L manual transmission. The car starts right up when I turn the key but has no power when I step on the gas. It wont go any faster than 5 mph.
I have tried testing the fuel pressure, its suppose to be 35-45 with koeo and 30-40 with engine on. I get a reading of 37 psi with a gauges using the test port on the rail. I have changed the plugs, wires, ignition coil, catalytic converter, all vacuum lines, new battery, pcv valve, tested the wiring for a dead short and a good ground, had the alternator tested, changed the o2 sensor and the fuel filter. Im about to get a new computer for it. I have also done a compression test. My car does not have an egr valve either.
i was told that a obd tester wouldnt help me cause the check engine light isnt on and they only tell you why the engine light is on.
March 22, 2008.
Check out the related content below while we wait for the question to be answered by a professional mechanic.
