Mechanics
ENGINE LIGHT IS ON?
2005 Ford Escape
Engine Performance problem
2005 Ford Escape 6 cyl Front Wheel Drive Automatic 83000 miles
the engine light is on and they said it was the 02 sensor and so we replaced it, but the check engine light cam back on! What should we do? How many sensors are on my truck and where are they located? We only repleced one do you think we replaced the wrong one? Also I hear a noise when I hit bumps under the hood on the driver side- its like something is betting or knocking on the hood of the truck, but its under the hood? Please help!
Mandygail08
March 4, 2010.
Check strut plates and sway bar links. Also, have the computer rescanned to determine if the code is the same. If it is, let me know the code so I can check into it.
AD
