1995 Toyota Corolla What is the problem with my distributor?
1995 TOYOTA COROLLA
65,500 MILES • 4 CYL • FWD • AUTOMATIC
2CP-ARCHIVES
  • 4,540 POSTS
1995 Toyota Corolla mileage: 65,500. What is the problem with my distributor? I have heard repeating noise from it when the engine running. I opened it and saw the rotor edge was damaged, so I replaced a new rotor that I bought from a local Toyota dealer. But the noise still won't go away. I also check ignition coil's primary resistance, which was 0.7 ohm [within specification?]. The secondary resistance was 12.51 K ohms. Additional information: 1. In Aug 2000, a local Toyota dealer installed new timing belts and new starter for my car. 2. Only the silicon portion that was connected to spark plug in engine # 1 turned to dark orange color. It was black color before the noise symptom. 3. My car had a new distributor at 32,500 miles.
Oct 18, 2010 at 7:38 PM
2CP-ARCHIVES
  • 4,540 POSTS
The problem with your distributor may be a bad bearing allowing the shaft to wobble. In addition, check the ignition system, it may be time to replace the cap and plug wires.
Oct 18, 2010 at 7:40 PM
CLARKEY
why no current going to the distributor
1993 toyota corolla
Jul 11, 2012 at 9:13 PM
