2CarPros - Car Questions & Answers
Ford Crown Victoria Repair Question
Topics covered: Gas, Head gasket, Coolant.
Asked on July 26, 2010
T
Gtrtetsw rtaswetb tertawe
Avatar Asked by jazzypha
Answer
Replied on August 17, 2010
It could be a few things. First, it could be a bad head gasket, but you said you checked that. Also, how bad was the radiator when you flushed it? Could it still be plugged? Finally, are you sure you didn't put the thermostat in upside down?
Tiny Answered by Jacobandnickolas (expert)
57,318 answers provided
ytryrtyrtyeryyyr
Tiny Response from jazzypha
1 question asked
Replied on August 18, 2010
If you are sure the head gaskets are good, the only other thing I can think of that would cause this problem is if the timing was out. Is the engine running good?
i7riuyui67uir6b 65y5rtyrtyurtuty
1 question asked
Sorry to jump in, but are you sure the vehicle is actually overheating, or is the gauge or light telling you it is hot? I would have a scan tool put on it and see what the ECT is reading. It may just be a bad sensor. Just a thought.
Tiny Answered by way2old
0 questions asked
It is all controled by the PCM. You can no longer adjust timing. Just to add to the other person's comment, has the coolant ever boiled over?
