Mechanics
SHUTTING OFF
1996 Ford Crown Victoria
1996 Ford Crown Victoria V8
My car will not shut off by the ignition switch. I have replaced the switch and a plug harness under the dash board.
D_crim
May 30, 2009.
Hi d_crim,
Thank you for the donation.
Symptoms indicates power is not being cut off when the ignition switch is turned off. Check the PCM power relay ( located in relay center at left side of engine compartment, inside item # 10) to see if it is sticking resulting in power not cutting off.
Unplug relay to see if engine cuts off.
http://www.2carpros.com/forum/automotive_pictures/192750_EngComp96FordCrownVictoria_1.jpg
KHLow2008
Jun 1, 2009.
AD
